Busa196
I recently brought my pit to a local/popular shop to have an oil leak fixed. I was told it was the starter seal and the starter was full of oil- which made sense as I could see it coming from that area- so they replaced it and also replaced the starter clutch.
I rode it less than 200 miles and it started leaking again- actually a little worse this time. So I brought it back this weekend and they called me today and admitted the leak was coming from the same place they initially fixed and told me that labor would be free but that they "think" the leak is actually coming from a bent starter shaft allowing the oil to come in from the primary?? He actually sounded a little perplexed. I'm calling BS on a bent starter shaft. I know this is the second starter in the bike and it only has 2500 or so miles on the second one (prior owner snapped the shaft and replaced it). I've never had any issue starting it or a dead/low battery when cranking her over.
Should they be looking at something else? A different seal? Forgive me as I've never seen the starter off the bike and looked today online for an exploded schematic of it and couldn't find one. I just don't believe a new $4xx starter is the answer and that's what he's telling me I need.
Really appreciate any input/thoughts guys!
, a search will get you all the reading you can stand on this subject, and from the pics I have seen of broken starter shafts, correct me if I'm wrong but aren't they hard? I have seen broken ones but not bent
