pauldeepsea
fired the bear up tonight, had sputtering at about 2400 rpm and after about a 20 minute drive I had white smoke from the exhaust. Got home and had air blowing through the top of the front cylinder sounded like it was coming from the center where compression release would be mounted. The bear only has the plugs installed. From what it looks like the plug may have lifted. Took off the air filter and one of the vent holes on the bolts that mount into the motor was plugged . Started the bike up without the air filter installed and the white smoke was gone and so was the air escaping from the front cylinder. At first I was thinking a blown head gasket but now I am thinking the motor was not venting? Any recommendations ?
Just my opinion, but tig has always been the easiest for me. You are in control of your speed and filler feed rate, and if ya have a foot pedal control, you control the heat! Once ya get the hang of it, it'll be the only method you'll want ta use. Like I said, cap the pipe ends of with a baggie or tape or something, and purge the air out with argon ant the bead indide the pipe will be as clean as the outside. Back in the day, I used to weld cryogenic transport tankers, and all the stainless or aluminum inner vessles were tig welds with full x ray testing. Got faith in ya man!!
