Fitzy
Hi Guys I have discovered a small oil weep in the head gasket on the rear jug on my bike so I thought when I replace it I may as well do both, so I may as well change the cam and if I do that I may as well shave the heads this could go on forever anyway. After a lot of research everyone here says 585 cam is the go would it pay to use the 585 and still shave the heads or should I go 600 if I'm going to shave the heads ? or don't touch the heads at all just cam ? and if I shave the heads how far do you go. I don't want a drag bike just thought if I have to pull the top end down may as well give it a bit of a tickle extra HP cant hurt. I would still like to run premium pump fuel.
08 Mutt 117
super G carb
2 into 2 big radius exuast
Your thoughts
Cheers
08 Mutt 117
super G carb
Your thoughts
Cheers
