MKTLAWYER
I have an '06 K-9 and had it in the shop to fix the starter but they gave up (a HD Shop) and returned it. I checked posts here and narrowed it down to make sure it was not weak battery/poor connections. New battery installed, I cleaned all connections today, I checked voltages per trouble shooting guides, service manual addresses electrical starter issues but not mechanical ones (bendix?).
Bike will make a real short attempt to turn over when starting, but then just stops before it fully cranks motor over (typically starts instantly if engine turns over). If I turn motor over manually (rocking it in 6th gear or turn rear tire while up on jack) then try to start, starter will turn motor over and it fires right up.
I thought it must be worn bendix. I turned back here and read so many more starter posts with so many different starter problems, that I'm lost and paranoid. I am unsure if I should pull solenoid, pull whole starter, fix bendix wire boot, see if there's oil in starter, pull of the primary cover and tighten a jackbolt or just find another shop to take it to and pray.
Does anyone know what my next logical step should be or should I just start on the drive side and work my way in (fix wire boot, pull solenoid, check plunger, check electrical brushes, etc,?????)? Or just ride it and rock it in 6th gear before needing to start it up (embarrassing) every time? Or pull starter and send to DOC? Please let me know. Thanks in advance.
Mark
Mark
