08 k9 efi throttle response
phatchopper300
I just wanta ride
Okay kind of make this short and sweet have an EFI bike my issue is bike rides great I had Matt at big dog upload a map on my ECM got it back installed it everything ran great one issue I have is when I go full throttle it feels like I'm hitting the rev limiter or there's no power the bike should keep pulling when I go full throttle.
I suspect the throttle position sensor(how do I test) could be the culprit any other ideas I could check I did at first have two codes one was throttle position sensor malfunction and bad rear sites which I both cleared and no longer get any DTC codes nothing in History either.
Thanks
Sent from my SAMSUNG-SM-G935A using Tapatalk
Jwooky
If you download protune from S&S you can monitor all the EFI sensors.
Highly unlikely that is you issue however. The TPS is very reliable and you would have a lot more issues if it was not working including faults.
I would focus on your tune.
Also they are self learning so riding it and merging the adaptive maps will improve the tune.
Matheny 514
I would agree, it sounds like the TPS is functioning properly.
It would be helpful to see what your sensors are reading while the bike is running.
phatchopper300
I just wanta ride
Well something going on went to hook up protune engine will turn over but not start checked plugs and no fire. ( scratching my head) bike ran fine yesterday other than when going to full throttle
phatchopper300
I just wanta ride
I'm such a dumb ass....lol.... been going back in my head and back tracking chain of events to lead to no spark...
Went out to garage felt behind coil and guess what all three wire behind coil the connector was disconnected. Reason way I put on both fiberglass washer that do under coil I must has pulled the connector loose. I will reconnect tomorrow and report my findings
