S&S Induction
TH81
I'm wanting to get the S&S Induction intake kit. The one with the dual filters but am unsure of model needed. I'm currently running the S&S teardrop which came with the bike when purchased. I emailed S&S but May get quicker answer on here. Anyone know which one needed for an 08 Pit(117ci). I also ordered the 2-2 vance and hines big radius. Currently have the 2-1 setup. Anyone have this setup and if so, what jets are you running for the super g carb? Thanks
TH81
If your bike has a carb than this one should fit:
https://www.denniskirk.com/s-and-s/tuned-induction-air-cleaner-kit-170-0084.p186124.prd/186124.sku
I have the same set up + big radius 2:2 + 585 cam at sea level.
I'm running 78 main jet and 33 intermediate.
Paul.
I see that that one says 4 & 1/8th bore.
This one says stock style head breathing. https://www.sscycle.com/products/ss...supsup-super-e-or-g-carburetor-chrome-finish/
I'm assuming I would need the stock breathing one??
TH81
I'm curious as to where you ordered them from I'm pretty sure that the v&h big radius is no longer available new and with correct bracket for a pitbull anymore I've only seen them available for the k9 and the mastiff
From what I understand is that every big radius exhaust is the same except for the mounting bracket. I ordered the one specified for the k-9/mastiff. I will have to fab or get someone to fab a bracket for an 08 Pit.
pauly
The link you posted shows one that is designed to fit heads with breather mounting bolts.
Our motors breathe through two (one small and one bigger) hoses coming out of front and rear head just behind the mounting bolts therefore our mounting bolts are not hollow!
Paul.
LoWeLL216
I was wondering the same. Are the big radius pipes all the same? Just different mounting brackets?
TH81
Yes, for any dog with a 117 motor they are the same, I'm pretty sure. Just different mounting brackets. I found someone to fab me one. I just need to make a templet.
TH81
Jeff over at Dead One Customs fabricated me a bracket for the exhaust. Worked out perfect! If anyone is interested in this exhaust on an 08 and up Pit give him or I a holler as I still have the template I made for the bracket. IMG_3413.JPG
