LoWeLL216
Yeah, like most have said, it sounds like I've got a fuel issue going on. I'll have to check things over and possibly adjust the carb.All bikes are different but never use the enricher when warm. Turning the throttle will work on some bikes and not others. You just have to find the "Trick" that works for your bike. If I turn the throttle on my RoadStar it will never start...
I figured it was weird having to use full choke in San Diego.
One thing I noticed (which may or may not be normal), there's a clear line of tubing running from a nipple on the top of the carb to the bottom of the bike (not connected to anything). What is this? I definitely need to reroute it regardless...
