Jersey Big Mike
100K mile club
Is there anything in that pic that is cool -- all I see is HOT!View attachment 35923 I use dual coolers, the oil stays nice and cool and make for a happy motor.
Well I am/was...Lol! Just blew the rear cylinder head gasket on the 124 in the K9. So, after I see what all is going in with that...I would like one for the K9.I'll be removing mine shortly as well. Replaced it and the stash tube with a PAIR of Pro One oil coolers.
You looking for an oil cooler?
I may be in touch in the near future, if it is still available.Original air cleaner was given away, stock exhaust was thrown away. I think this time I'll most likely polish it up and sell it....
How many miles on the 124?Well I am/was...Lol! Just blew the rear cylinder head gasket on the 124 in the K9. So, after I see what all is going in with that...I would like one for the K9.
No one knows. Original owner of the K9 picked it up at a swap meet out of a deceased Iron Horse. The motor has about 9000mi since it was installed in the K9. Nice part was with the blown gasket, there was no oil leak...just air. Inspection of the front head, no problems. Clean and solid. Having trouble getting at the rear (one that blew) because the motor is so close to the frame. May have to remove the motor to get at the head.How many miles on the 124?
Oh this is your new K9. Forgot you just got the 124No one knows. Original owner of the K9 picked it up at a swap meet out of a deceased Iron Horse. The motor has about 9000mi since it was installed in the K9. Nice part was with the blown gasket, there was no oil leak...just air. Inspection of the front head, no problems. Clean and solid. Having trouble getting at the rear (one that blew) because the motor is so close to the frame. May have to remove the motor to get at the head.
Let us know what you find. Also what were the conditions upon the gasket failure? Under heavy load? Or just cruising along?No one knows. Original owner of the K9 picked it up at a swap meet out of a deceased Iron Horse. The motor has about 9000mi since it was installed in the K9. Nice part was with the blown gasket, there was no oil leak...just air. Inspection of the front head, no problems. Clean and solid. Having trouble getting at the rear (one that blew) because the motor is so close to the frame. May have to remove the motor to get at the head.
Where is Sven when you need him? The fins on the cooler are there to increase surface area, much like the fins on the engine. Difference is there is no combustion (heat producer) or moving parts in the cooler causing friction (also a heat producer). So all there is is heat exchange going on from the cooler. Clearly, no matter how hot it is outside, the outside temp is cooler than inside the engine, thus reducing the temperature of the oil. Having had both set-ups...it works.I have never had oil coolers and any air cooled motorcycle i have owned, i can't see how if your stuck in traffic and you don't have air flow how it can be 20 deg cooler?
Putting around town in summer (32-42 Deg C) it constantly sits on 200 -212 F and out on the open road down to 180 -190 F.
I have my tool bag under my head light as well, but i look at those pics and see the downtube oil coolers restricting flow to the motor also putting hot air directly onto the motor.
Not for me.
I hope. Or may be on Old Faithful!So heading to Daytona with a brand new head gasket to show off with, huh JR?
Did you get those foot pegs for K9 Someone in Fayetteville was looking for extended and had originals...I hope. Or may be on Old Faithful!
And some people still wonder why some have multiple bikes......I hope. Or may be on Old Faithful!
I'd be interested in that if JR isn't.Did you get those foot pegs for K9 Someone in Fayetteville was looking for extended and had originals...
If you do a lot of city driving in the summer they help but the oil has to get to 200* to burn off water and contaminates so under 212* is not a bad thing. A buddy of mine put a big oil cooler on his Corvette because it was running at 220*. It brought it down below 200*. A year later the motor blew and they told him it was because of the oil cooler...I have never had oil coolers and any air cooled motorcycle i have owned, i can't see how if your stuck in traffic and you don't have air flow how it can be 20 deg cooler?
Not for me.
Lol...ended up with two sets of stock and one set of extended. Was going to sell the extended and the extra pair of stock.Did you get those foot pegs for K9 Someone in Fayetteville was looking for extended and had originals...
Pretty sure. Blowing air out of the middle of the rear jug on the left side. Loud air leak! Not much oil though, so fingers crossed...no internal damage.And some people still wonder why some have multiple bikes......
Are you 100% sure it's head gasket? Not a very common issue.....
So matheny above is buying, you are selling. That sounds almost like a deal!Lol...ended up with two sets of stock and one set of extended. Was going to sell the extended and the extra pair of stock.
