Moespeeds
Hey guys, after installing my new belt drive I'm having an issue getting my front pulley tight enough. I munched two charging rotors this week, and the nut backed off last weekend, seizing my belt drive. On the advice of a mechanic friend, I'm mounting a heavy duty rotor, it has double the spline depth of stock so I wanted to mount it with no washers. I still can't seem to get that sucker tight enough, so I've also added a small washer, about the depth of a penny. Even without the washer I'm barely pushing 1/2" of spline sticking out for the pulley to grab. With the washer I'm about 7/16". Is this enough spline area for the pulley to hold onto? I'm running an S&S 117, with a 3/38" Ultima belt drive. In the pics below I've already torqued the nut on, then took it off for the photo, so the crank and flywheel should be pulled into position.
