What is this ?
Going to take a stab and say it's to adjust your peg in case you need clearance from aftermarket pipes?
Are you the original owner?
Srodden
Not original owner quite sure no mods were done from original. Thinking swing arm is made for more than one model ?
jimizee028
TRUE COLORS COLLISION
I cant freaking believe someone that owns a Mastiff hasn't gone out to look at their bike to tell you what this hole is for...Dumbfounded!!!!!!!
Srodden
I actually sold this bike and new owner hit me up wondering what it is. I thought I posted this question before but quite a while ago
I originally looked at the pics and his bike listed under his avatar, 2011 Mastiff but was confused because the belt was inside the frame:oldconfused: and I thought rear belt guard mount but mine is above the belt, so then I see he stated it was for an 05' DAH:oldbang:. 06'nd up have the 300 and the belt guard is above the belt. But I think someone removed the belt guard and never put it back on, cause the hole is used or did they just run a tap in it to clear out the powder coat.
Here's the 07'
Here's the 07'
I was thinking da same 1 bolt hole under the belt??
