I welded mine about 2 years ago.. still good to goMy bracket cracked at the lower bolt to frame location. My question is where can I find another and can this bracket be welded and still hold?View attachment 35491
I don't believe you. What do ya think? would rubber washers from Lowes or Ace hardware stop the vibration and cracking??Weld it up, buy 2 3/8" thick rubber washers from Lowes/Ace hardware and put it back together. The washers will stop the vibration and stop the cracking. If you don't believe me, just ask me...
( hey, ya said to ask!)
Yeah I posted a thread a bit ago about switching back to avon.. as much as I love my Metzler and everything I have has em, just not that great for a 300.. can't align wheel perfectly straight.. so yeah I know it's time fore tires.. lol.. but good lookin outThats bigkelk9 pic
Loose bolts on your exhaust, back to basics as I have learned the hard way.. these things rattle like crazy.. check all your bolts and screws often..I removed the bracket to get it welded and it looks like its a used replacement as the previous owner must of had too replace his original. Other than loose motor mounts, what could cause this complete fracture of the bracket?
At least your eyes are not failing youWeld the bracket,and is that a crack in the tire there,
Straight up from that weld, looks like a bad spot in the tire.
Looks like that was welded in the corner before?
No.. just a poor welding job.. lolLooks like that was welded in the corner before?
