2004 intermittent spark
ninja11zx
Ok, i work on mostly jap bikes so bear with me. working on a 2004 b d for someone. ran and i repaired all i needed to do and now it has intermitent spark. wont fire. he said was new barrery but will barele turn over. wiring looks like a night mare. has anyone just junked this system and installed a dyna? looks simplest to me. i dont see the led lights i am reading about. where to start? thanks
Post a few pics of the wiring and somebody will know what you are dealing with.....maybe something simple?
Never seen that black box. Where the wires go? Where's it mount anyways. Is it some LED lights bullshit?
That's an 03 not an 04 too just an FYI
I'm with Eric. Maybe shorted out leds? Unsolder the wire you fixed and see if she fires.....
Hirter6Pack
Not Quite A Guru
If it was runing before you soldered that wire check it again, both ends. Make sure you don't have a cold solder and that you have a good connections.:oldthumbsup:
ok, build date is 05/03, he said was a 04.he bought it new
not a big deal I just wanted you to know because there is a BIG difference in electrical issues between an 03 vs 04 and electrical schematics. As well as some easier troubleshooting
You got Harley Switches and a pretty basic control unit. With an 03 you have lots more options.
Let us know where those wires go. They seem kinda large awg for LEDs but I'm not sure what else it would be.
Maybe an old security system they lost the fob for, so they just unhooked it?
ninja11zx
Well got home today and the damn thing started. i would say battery was to low. wiggled wires and nothing acted up. if happens again will hit you guys up to wire old school. thanks for help. now have to call becouse think speedo isn't working. where is pickup for that?
its on the transmission
ninja11zx
One other thing, why are the brakes fixed and not floating? Rear caliper has a bunch of washers stacked. He says always has trouble with rear brake so after looking at it I'm making it a floating hanger.
Floating is a sport bike thing. Fixed on real bikes Big Dogs and Harley's..I had to!
I'm really not sure you have room, you'd have to scrap the stock bracket then you'll have spacer issues on your rear tire.
Shim the caliper appropriately, less work.
