Broken 06 mastiff clutch cable help
watty
I was riding my mastiff went to pull in clutch and cable snapped,it felt like the lever had broken.Upon sneaking home,thru a few red lights in gear,I pulled inner cable out thru sheath.It had broken inside the ball and ramp area.Here is my questions,what size cable should I use for a 2006 mastiff(model # and size) should it be big dog replacement or another brand due to all the posts of the originals breaking so soon.I would like to keep the shiny and clear coated style.Any suggestions on where to purchase.thanks Watty
watty
watty
I'M STILL TRYING TO FIND OUT ABOUT CABLE LENGTH ON 2006 BIG DOG MASTIFF.I called barnett cables,my question is this,the stock handle bars on this bike with slight pullback were they known as drag bars or pullback bars.Ordered pullback and I'm now questioning my order? We're the stock bars were called drags or pullbacks since they seem like they could be either,low with slight pullback,help please,while I can still change order if necessary
pknowles
RETIRED
post a picture of our bars and one of the other mastiff owners may pop in
toomanybikes
not enough time 4 riding
The part number for the clutch cable, probably a Big Dog part number, for my 2006 Mastiff which was replaced in 2009 is 111-000004-00
Did a google search and found this (which is from the Technical forum on this site)
alright I went to the shop & got the #.. now this is what is listed for a 07 pitbull...
length..63inch
BDM # 111-000004-00
BARNETT# 102-30-10010
DRAG # 0652-0535
now all these # are on the package.. the barnett came in with the barnett # & a drag # on the bag... the bdm came in lose & has a paper tag on it.. the only differance in the cables are the barnett has the adjuster mounted in the cable length about 1 inch closer to the hand control.. & the barnett has a spring looking covering ( I guess as a anti kink or heat shield ) where the cable enters the tranny.. now from what I here barnett builds the cables for bdm.. thay both look the same except for as discribed. hope this
