WildBillNick
Speedometer quit working but I suspect a bad cable. Removed speedometer and cable from the cable housing going to front wheel Speedometer Drive Unit. I stuck the cable end into the speedometer and spun the cable. Speedometer showed to respond and move. However, cable end that inserts into front wheel Speedo Drive Unit seems buggerd or broken off. Cable may be broken off inside the front Speedo Drive Unit. I cannot tell for sure if that is a pin inside the Drive Unit or a piece of the cable itself. What ever is in there I cannot retrieve it with small needle nose pliers. See Pictures!
the cable itself measures 42 1/2 inches long, or it may suppose to be 43 Inches long if not broken off. Steel Braided Cable Housing screws into the front wheel Speedo Unit.
Question 1: Is there suppose to be a pin in the front wheel Speedo Drive Unit?
Question 2: Does anyone know if the cable is provided separately or is the cable and housing sold as one piece?
I attempted to contact Wild Steel Works, but they are closed until July 15th or maybe longer for relocation.
Question 3: Does anyone know of another supplier? I also checked with J&P Cycles but they do not list anything for a Big Dog and I do not know what would possibly cross reference to a "H a r l e y". I once attempted to ask the partsman at Stokers in Dallas for info for rear brake parts evn though they had a few Big Dogs on their show room floor, but the partsman was kinda shitty then he went into a rant about other bikes that he didn't want to support. So I wont deal with Strokers anymore although Rick Fairless and the girls there were pretty friendly.
I appreciate any help..
Billy
Billy
If I'm right, (every once in a while I get lucky,) IF that's a piece of broken cable I don't believe it'll be in there too awful tight.
