Twisted
Well I was having headlight problems the past couple days, every one in a while the high beam indicator would come on for no reason while riding then go out. Then yesterday it was going crazy, would go on, then off, then start blinking and when I got home I had no headlight. So I opened up the headlight housing to find some rewiring, the plug grounded to the housing and a thinner ground coming out of the harness completely melted. It had already been upgraded to the ceramic plug but no mater what I tried I could not get it working. And I had a bunch of blinking light on the ehc, so I now I'm thinking a short somewhere or my ehc is going. Even tested the bulb hard wired to the battery, power to one side lit it up but power to the second terminal had nothing but at the time thought nothing of it, bulb works. Today when I got home I checked a few more things and decided to pull the tank to check the harness connector to find the plug was gone and they were spliced together but the black ground had been cut under the tank and wasn't even in use. So the melted ground was not even doing anything and must have been melted from the previous repair. So I went back the bulb that only lit on one terminal and figured I'd get another to rule it out and go figure it was the f**cking bulb the whole time. Put it back together and all seems well, so as they say start with the simple stuff first!!!!
My old sayings goes "if it's save and no broke, don't fix it!". Ride it like you stole it!!
I just don't understand why we make things more difficult than it needs to be.......
