How to removed front signals bucket??
nextbd
Hi
I need to replace one just of the front signal buckets because is in bad shape so can somebody tell me how to removed it?
Thanks!
Alex
Marky-Marc
Take the turn signal lens cap off
take a small pick or small screwdriver and gently pull the LED flat light out with the rubber weather cap around it.....
Unplug LED light from connector and remove
I do believe you will have to pull the JST plug off to get the wire harness out of the old bucket, quite simple, just take your time, and gently remove the wires from the plugs using a tiny pic or screwdriver...do not damage the connectors or they will not go back into the white JST plug and stay.
Inside you will find a 1/2" bolt that threads into the triple tree, remove normal (lefty tight, righty loosey)
(lefty tight, righty loosey)That's vise versa.
nextbd
Great, Thank you very much for your help!!!:old2:
See you Friday I hope brother!
Maybe you can show Him how that Lefty Tighty, Righty Loosey thing works. Maybe too much skype with Russia? Got you all backwards?
And wheres the rest of the invite for us? It's more humid than a hookers vagina here. North sounds good. hahaha.
I do wish I had time to go ride up North though.... :(
Y'all are invited. This in an open invitation to anybody that's in the area.:cheers: And I am going to show things he's never seen before. :oldsmile:
