Battery install- Horn sounding
Pam
Hi Guys, We fully charged our battery after the winter and installed it (we checked and even took it back to the store to be sure it was charged). Problem is that when everything is connected, the light and the horn come on and wont shut off. Not sure if the wires are all connected correctly on the battery (one black and ground on the negative and two red and one ground on the positive) or if is some other problem. Simple but frustrating... Thanks for the help!
MossBerg590
Shouldnt have any ground wires on your positive lug of battery. If the bike is stock should be one fat wire from starter,one wire from vr and one wire from ehc all to positive side, these should all be red wires. Ground cable should have fat ground from starter, and at least one more ground wire from the ehc. Should be all black wires.
Hirter6Pack
Not Quite A Guru
Yes that and I also have a ground wire going from negative post to chassis.:oldthumbsup:
Pam
So sorry, misspoke. There are two thinner wires, one that does to neg and other to pos, but the factory for some reason made them both black so I was calling them both grounds when they are not. So there are three wires that go to pos and two that go to neg. Their length really makes it so you can only connect them that way. What is odd is that the with the neg all connected, when we connect the pos wires it always seems to be that thinner wire (last one on) that causes the horn and light to turn on. Didn't know if it was maybe a short or if anyone had an idea as to why it is doing that. Had the bike since 06 and done this every year without a problem. I've seen reports of a horn going off if the battery is low but doesn't seem to be that issue. Could be water gettign into the system (we did just wash it) but we had it sitting in the sun several days so should be good.
Brew
Your control may have water in it. Take a hair dryer or if you have a forced air dryer, try that. Hopefully it's simple as that.
Rottweiler
The two smaller wires slide the black covering back and look at what the wire color is. They both go to the ehc one is black to NEG and one is red to POS. Also what plug is near the larger black wire?
MossBerg590
The thin wire you say that causes the horn to blow when hooked up is the power to ehc. Could be a short somewhere in wiring or the ehc is shorting for some reason.
MossBerg590
Also as brew said, take your ehc connectors off, clean them out, blow dry them and regrease. If you just washed it it sounds like water may have gotten in and is shorting the connectors out once power is hooked up to ehc.
Pam
Thanks guys, that's what we are beginning to think, that it is a short. We have a mechanic friend coming over tomorrow to look at it... will share with him your thoughts!
What does the JST connector go to that has nothing in it, its right behind the heavy ground wire?
Also the ring tongue terminal by the heavy ground cable has electrical tape on it and it looks like a red wire under the tape.:oldconfused:
That's an extra plug. Both Gary's K9 and Bryan's Mastiff have it too.
Pam
Thanks guys. Our neighbor is a master HD mechanic and he looked at it and didnt know what the problem was. We took apart the EHC, cleaned, dried and re greased everything and the horn and light still coming on when the battery is connected. If you have any other ideas, would be much appreciated. Anybody know someone in central Ohio who still works on Big Dogs?
According to your profile you have a K9 2016, it is still under warranty and I would think the new Big Dog would take care of that for you. Did you call them?
I still think you have a wire mixed up:2cents:
Marky-Marc
Even with the horn and light issue, does the bike start and run normally? If it does start and run normally, what does the light do (flicker), does the high and low beam work? Does the horn keep sounding when the bike is running?
  • Like
Reactions: Pam
Marky-Marc
check all your fuses. A blown fuse is may be preventing the key from resetting the box under the seat. Basically what's happening is, the RIP or EHC, whichever one you have is NOT getting a signal to reset after the battery change. Check ALL the fuses. You can try connecting the battery then turning the key on/off (don't start it) around 5 to 6 times to see if it will reset the 'box'. If it doesn't, look for a blown fuse or a blown relay.....
I would still like to know what happens when you actually start the bike up after connecting the battery, regardless if the horn and lights are on....
Also, if the key switch is not working correctly, it's not allowing the box to reset...so, give the above a try, start bike, see what it does, or just turn key on/off 5 or more times, also take a look when you turn the key to the on position that all your other lights on your speedometer come on and work as well.
  • Like
Reactions: Pam
