Coolbreezin
A couple thousand miles ago I had my clutch plates replaced with a standard 12 plate kit. (I was not informed of a 9 plate kit option) After some time and adjustments I still cannot get into neutral at a light. It still drags a little but not so bad I cant hold it with my legs. (Yes, the clutch is adjusted correctly) I was talking to a friend of mine that builds bikes and he said that he had heard of removing 2 plates (fiber & steel). If the pressure isnt enough, use washers behind the bolts. Before I crack open the primary, I'd like yalls thoughts.
