Unfathomable noise
mjsk9
I know you said all your heat shields were tight.....take them off, go for a ride and see if it still does it.
Does the noise go with the RPMs? Does it get faster over 2500 RPM?
It could be many many things....could be a loose spring on a valve, could be a pushrod bleeding over....etc. etc...
Since WE can't hear the noise, you say it 'sounds' like sheet metal....take your heat shields OFF-even though you say they are tight and go for a ride.....
Leave the clothespin in until you find the noise.....
Regarding the rear exhaust bracket. I believe someone mentioned that it could be loose. The exhaust bracket for my V&H was tight but it had a crack the entire length of the bracket at the weld. Had it re-welded and took care of the sheet metal rattling noise.
I had an odd noise in the front of the Pit...turned out to be a broke compensator spring. Its hard to pinpoint noises sometimes. You'll have to go over it with a fine tooth comb until ya find the bugger.....just let everyone know what ya figure out.
Dragonslave
Where is the compensator spring?
zenbiker
I will certainly look into the compensator spring because that is what the noise most most sounds like... A broken spring.
Thank you much.
