Thanks for your reply, Besides the spectro and red line do you know any other option??I wouldn't put it in mine.![]()
But if your bike don't leak the colors of the rainbow,I run the Red Line. Trans Fluid with shockproof. A lot of guys do. I use the gear oil for the primary. I have the old style primary (LSD). Baker reccomended either the Spectro or the Redline. I like it because any leaks are color coded! Pink Puddle...trans, Green Puddle...primary, or Purple Puddle...Engine Oil (Royal Purple). Its like fluids for dummys!
Buddy, your not here that much and I can't miss the opportunity.
I expected it!But if your bike don't leak the colors of the rainbow,how do you know whats in there![]()
I use the standard Harley primary oil in my primary![]()
Hi! and please tell me-exactly-the full designation of this oil. And the red line has a lot of similar oils and I do not know what exactly is needed for the transmissionBack when this site started Redline Heavy shockproof gear oil, all synthetic formula was what most were using and if I remember correctly Baker was recommending it. Kind of like S&S said to use Mobile one until another company made them a better offer. All about the $$$$
Mr. WrightOn the bikes that are 05 and newer it is recommended that you use Lucas 75w 90. The red line is not recommended for these transmissions because it is too thick and will not properly lube the inner bearings around the shafts.
Online Baker & Jim's transmissions 04 and older this does not seem to be a problem.
That bike is a regular rainbow warrior, eh? HahaI run the Red Line. Trans Fluid with shockproof. A lot of guys do. I use the gear oil for the primary. I have the old style primary (LSD). Baker reccomended either the Spectro or the Redline. I like it because any leaks are color coded! Pink Puddle...trans, Green Puddle...primary, or Purple Puddle...Engine Oil (Royal Purple). Its like fluids for dummys!
SKOGDOGThat bike is a regular rainbow warrior, eh? Haha
I am another who uses Shockproof Red Line in my K9 transmission—no issues so far.
