David witzke
bike had new rip kit installed and a new vfi installed. Bike starts and runs for 1 second then dies, any help would be greatly appreciated.
Where did you buy it?bike had new rip kit installed and a new vfi installed. Bike starts and runs for 1 second then dies, any help would be greatly appreciated.
I had a similar thing happen. It was just loose, but enough to ground out the plug wires. The efi wires are tight to the heads. Especially if the fiber washers are missing like mine were.Check your coil
I just went through this with a 2010 Bulldog
Mounting bracket was broken and the front plug wire coil boot was pushed against the front head.
Everytime the motor fired it would short through the plug boot and make the Ehc reboot causing the motor to shut off.
