High/low beam problem
bonannomd
Hello everyone, I'm wondering if one of you folks can help me out.
I took my bike for a ride the other night and when I switched the headlight from Low beam to High beam everything worked fine. the light switched and the blue indicator light came on. Now when I try to switch back to low beam the blue light just keeps flashing and will not switch to low beam.
I disconnected the battery and then when I reconnected it the High beam is still on. I pulled the light out of the bucket and everything looks fine. I thought maybe the switch was bad but it must be doing something since when I press the low beam button the blue indicator light will flash. Would anyone have any Idea what might be wrong.
BadDawg Bill
Thank you very much guys, I appreciate the help. I will check the low beam and replace if blown
Wait until you try to get the headlight ring off.... I'll bet you will be thinking about a LED light that will last awhile instead of another H-4 bulb.....
