Re Tire
Chutney77
I have a 05 chopper. I believe it is a 240 rear. Does anyone know if I can put an oversize tire on that rear?
Any info is appreciated.
Thanks, Chutney77
Thanks, Chutney77
You're 05 Chopper came stock with a 250mm Avon tire. I get about 19,000 to 22,000 miles on each. Not much room to increase the size of the tire as the belt is really close to the tire!
But 250 is just fine for everyday riding!!!!
narow37
Angry Southern White Man
an 8.5 inch rim will fit either a 240 or 250 but you may run into tire rub issues with the frame unless you play with the rear wheel spacers.
edit: sorry I thought it was a 240 on the chopper but Ray should know
BBChopper
Supports 2 Disabled Vets
:eek: :eek: :eek: :eek:
I waz gona sat WTF!
Oh you didnt get that out of that last rear! That sucked dude!
I waz gona sat WTF!
Sucks when you buy a brand new tire that cost you several hundred dollars and then have it wasted by a big cut!!! :angry: :angry: :angry:
