Peckerwood
Going on a run tomorrow and all of a sudden my gas tank won't vent. The vented cap is working perfectly. Leaving early tomorrow. Any quick ideas or fixes, or will I be unscrewing the gas cap every 5 minutes on the ride?
Sounds like that cap vent isn't venting! could there be something restricting the fuel flow intermitantly?Going on a run tomorrow and all of a sudden my gas tank won't vent. The vented cap is working perfectly. Leaving early tomorrow. Any quick ideas or fixes, or will I be unscrewing the gas cap every 5 minutes on the ride?
I'll look into that in a couple of minutes.You would think with pressure in the tank, it would push it out the carb overflow
I've been wondering about this since the problem arose. Doesn't seem right, does it. Harley tech told me yesterday their split tank models have a vent hose coming from the tank. I removed my dash, there is a nipple on the right tank that looks like it could serve this purpose, but it is capped off by the factory, and always has been. WTF???So really there is now way of letting pressure out of the tank.
Just checked that, it's not blocked. Also checked the carb overflow hose, it's clear. I'm starting to think the vent on the gas cap was partially blocked, and when I took it off to check it by sucking on the cap, I might have dislodged a piece of debris. Can't think of anything else to look at, so I guess I'll make the ride and see how it performs. Worst case is I have to keep unscrewing the cap on the ride to vent the tank. Thanks for all the suggestions. I have a couple of hours before I leave, if y'all have any more idears, let me know.Mine does have a hose that runs from tank to tank.
I wonder if cleaning it, did you move crud and block it up? can you move air thru it?Serviced the air filter. Cleaned the crankcase vent filter.
