Any ideas on what brand harness this is?
wedan426
I got a 07 K9 and i was told that the bike had been rewired but i cant find any brand on the harness or controllers. Curious if anyone might know by looking at it. There is a tag on one of the main harnesses with a date of 8/14/15.
20160409_222153.jpg 20160409_222142.jpg 20160409_222108.jpg 20160409_222058.jpg 20160409_222310.jpg 20160409_222243.jpg 20160409_222204.jpg
MossBerg590
Thats a thunderheart module..judging by the sticker that says k9 its a r.i.p. because thunderheart doesnt label for big dogs
wedan426
I think you guys are right thanks for the help. Right now the harness controller is 2 sided taped to the back of the ignition module I don't know if it's easily seen in the pictures. Is there a better way of mounting this module?
MossBerg590
The r.i.p kits come with a bracket. When I wired my thunderheart I used one hole that was in the battery box already and drilled another one so it mounts to the box itself. Put some foam under and on side so it is well padded.
wedan426
I wonder if I can purchase just the bracket
Tomtang aka Reptilejim
Call Laynna at Big Dog (316) 260-8039
I'm sure she will take care of you.
Curtis I have 2 questions. I'm replacing my rocker box gaskets on the front and rear. Can I place bike in 6th get tdc, make sure pushrods at their lowest, then remove the assembly?
Second question is I can't find my primary gasket set I purchased from you awhile back.. I'll probably need to do purchase again. How much?
Sent from my SM-G900P using Tapatalk
