That would be a huge TRU-DATThankfully
They are dumbasses. I used Dynabeads years and years ago. Worked fine for me and my Ridgeback.I had four new tires installed on my Tahoe today. I asked them to install beads instead of wheel weights. They told me they could not do it. I asked why not? You install them in large truck tires. They said the Tahoe tires were too small. When I told them I had beads in my motorcycle tires they said it was not possible and would not work.WTF?
I did this on the last set, sure crap the weights came off. This time around I simply turned the tire on the rim until it was perfect. My front wheel needed a penny size weight and I can live with that on the outside.... But when you ride 25 miles a year I guess it doesn't matter, for us it matters......For vehicle tires, the led weights are much cheaper, and I always install them on the inside of the wheel so you can't see them. I have had guys watch me do this and say its not the same on the back, I tell them to place it back on the balancer, and its spot on. I've been doing this since the early 70's, they become believers in a hurry.![]()
When you get new vehicle tires, the yellow, white or red dot is where the valve stem is supposed to line up, the tire is balanced to compensate or the valve stem.I did this on the last set, sure crap the weights came off. This time around I simply turned the tire on the rim until it was perfect. My front wheel needed a penny size weight and I can live with that on the outside.... But when you ride 25 miles a year I guess it doesn't matter, for us it matters......
