If that doesn't workI used box tape. Clean it real well, stick the tape to it with a few inches hanging off to pull with. Worked great after fighting it by hand for 10minutes.
Get a can of PB Blaster and spray it . Wipe the ring off and get a pair of rubber gloves and stand beside the bike. you can put a lot more force on the ring than standing in front. If you have the set screws out it should give up.thank guys, I'm giving up. I'm going to take it to the shop today before I take a hammer to it.
I tried that already, I have had this out twice before, it shouldn't be this difficult. It's going to the shop this afternoon.Get a can of PB Blaster and spray it . Wipe the ring off and get a pair of rubber gloves and stand beside the bike. you can put a lot more force on the ring than standing in front. If you have the set screws out it should give up.
About 11:30 last night I was thinking that was a good idea.I bet a fukn hammer n chisel would work![]()
no no, after my mishap, my wife said to me, I knew it wasn't going to go well when you picked up the 4lb hammer
How did they get it offAll is well after a visit to the shop, had to buy a new HID set up. The old one was toast.
Trade secret.How did they get it off
I would put a dab of silicone in it to keep the water outThey had to drill a small hole in the trim ring, not all the through, just enough where the could use a punch and small hammer to get it to turn. When he put it back together the small drill hole is at the top where you can't see it. It's not a very good design to start with, I can live with it.
Now we're talkingThey had to drill a small hole in the trim ring, not all the through, just enough where the could use a punch and small hammer to get it to turn. When he put it back together the small drill hole is at the top where you can't see it. It's not a very good design to start with, I can live with it.
A little anti seize might help in the future if they put any on
