wedan426
is there a procedure for checking the compression realeases?Sometimes ur compression releases stick. Also. My starter motor came loose from the starter houseing and caused the same problem once.
Sent from my XT1254 using Tapatalk
just checked out the wpx20l for only 99 bucks..i'm trying it
i might look into this. thanks for all the help guysWPX20L-LS (500 CCA) old one was 270cca, most others are only 310cca
Sold by: PowerSportBatteries
$99.95 Deivered from Amazon
Pull the green wire off the starter and turn the key on and try to start it, you should hear and be able to feel them engagingis there a procedure for checking the compression realeases?
Thanks a bunch I will try this firstPull the green wire off the starter and turn the key on and try to start it, you should hear and be able to feel them engaging![]()
Put your finger over the rubber boot, depress enough to feel the compression release, start bike and feel it work. Move to the second one and repeat.is there a procedure for checking the compression realeases?
None of us do until we order something, then they pop outta the woodworko well ill try it out if it doesnt work ill buy something else. i didnt see all the other threads about it![]()
I know I put gluten, I'm old and can't spell!Voltage looks good but remember it's the cold cranking amps that matters. I've ordered batteries off the web 3 times before (gluten for punishment), and they also had great voltage out of the box. But didn't have enough ass to turn the Dog over. JMO
Which one do you have? Lightning start or BrailleWell mines over a year old and still spinning the shit out of my 107
