Baker transmission fail
Eric creed
Well I'm going to attempt to take out my baker transmission out my 2008 tomorrow since I can't find anyone who can tell me what might be wrong with it. Some shops tell me it might be the gears and some say it might be the shifting forks. I just can't believe a bike with 13,000 miles on it is all ready giving me transmission problems
FrankBDPS
Well Eric you can believe it. If you use the search feature found at the right hand top of the page you will find plenty of threads about the Baker right hand drive transmission.
The best thing to do is to contact Andrew Barnes at Barnes performance motorcycles in Endwell New York. He can build those transmissions in a dark room with his eyes closed.
Good luck.http://barnesperformancecycles.com/index.html?redirect=false
SKOGDOG
One of the old ones.
Hi Eric--Ditto Tom and Frank above. Hopefully you have a manual. Just as important are several good Forum threads on this topic. I don't know your skill level, but stay organized---not a bad idea to take iPhone pics of things because you'll have a while until you put it back together. Some use a magnetic dish for nuts and bolts and label sandwich bags to keep it all straight. Another tip from Blacktopper is to get a big cafeteria tray to put under the bike to capture any oil, etc.
Use a wire wheel to clean bolts, and you'll find a cheap set of bottom taps at Harbor Freight to clean Loctite out of bolt holes. Your torque wrench will thank you.
Barnes is generally recognized as having set the standard, so he is busy and you'll have to wait your turn. He's honest, communicates well, and will do a good job. Most expect to pay $750+/- for bearings and seals...mine was $1,500 because of defective shifters, etc. worth every penny.
The transmission has to take a real beating given the power these bikes make, and to pull up short will cost you. A whole different ball game than the Harleys.
Lessons learned:
1. Do it right the first time. Follow the manual and read Forum threads.
2. Do NOT abuse the transmission in higher gears.
Downshift to pass
Do not use full throttle in higher gears at lower rpm...1st and 2nd only.
Rarely do I ride at less than 2500+ rpm...usually cruise closer to 3,000.
No 6th gear until at least 65-70 mph. It's an overdrive, meaning the engine is turning fewer rpm's than the transmission (.85:1, I think). Consider the forces at full throttle at say 2200 rpm--the acceleration curve will be sluggish, but the engine torque generated will be considerable. Torque force can't go towards quick acceleration because of the low rpm and high gear ratio, so it goes right through the gears (4,5,& 6) to the bearings, as Woodbutcher says. And after the bearings fail, they can sieze, spin, and ruin the transmission case.
Sorry for the long post----maybe I need a twelve step program or something.
FrankBDPS
Lessons learned:
Downshift to pass
Good advice Rick.
francoblay1
The Spaniard
Lessons learned:
Downshift to pass
Spot On! :old2:
:chopper:
Eric creed
Just had mine rebuilt by baker. You can read my rants, I'm furious and I made my thoughts very clear to them. In the end still cost me a grand.
Sounds like what I'm going to have to do. Did you take your transmission off or take it some where?
Eric creed
Lessons learned:
Downshift to pass
No man thanks so much for the information. And as for Bernie he's going to be to far for me. I got a lot done today but got a lot more to do. I'm just hoping I'm not going to have to replace the entire gear set
If the back tire is in the air your good, you do know that the whole primary drive has to be removed also, to be able to get to the bolts holding the tranny and primary back plate together,
FrankBDPS
I am in Ohio. I took my transmission to a place called Pac Ship. They boxed it up and shipped it to Andrew.
