fork issue
The axle bolt will only go in from one spot on the forks.But that can't be right because my fender mounts need to be on the inside.What am I doing wrong?
Dragonslave
You should be able to spin it around if you haven't tightened anything down yet. Loosen and spin. The axle should slide in from the left to the right if you are standing in front of the bike.
