Avon Rear Tire
Lorenzo
I think I'll give em a try. Got a good online or retail recommendation for them? Safe trails.. :chopper:
I don't remember the web address but just type in Google, Shinko and there will be plenty retailers. there is a seller on Ebay that just sells tires and he has the 300 35 V18 I believe they are, for $187, free shipping and it took about 5 days to get it.
tim.sorrells
I just got a 250 Dunlop from bikebandit.com in 1 day shipping. Been running Avon, however, I got low mileage and worn out tire so I switched this go round.
Sent from my SPH-L720 using Tapatalk
SMCT
Does the K9 that comes standard with the 300 35/18 tire have issues with the sidewall and the drive belt? It's a factory installed Avon tire on my 06 K9 and I just bought a replacement Avon tire for it. I am in the need of a drive belt because there is a portion missing, as if something chewed it up. After reading this thread, now i'm wondering if I have to clearance the side of the tire. I need some educating on this topic. Thanks.
You should not need to that's only on the Metzler tires. Avon should fit like a glove if it doesn't someone might have put the spacers on the wrong side or soemthing else is wrong
And its only on some bikes, the last 300 Metz I put on cleared my belt. :whoop::chopper:
Joke•ster
My new Avon lasted one season, if you do run this tire you need to run 42 psi, a little extra..a bad choice if you run a hard tail, that extra psi will make it a long day...
My soft tail with hard psi feels fine... Avon.
