Everything I learned about my DOG was from BDB...so...
Marky-Marc
Just flip it over or does that make the tire tread backwards? Might have to swap the hubs because for a fact brake rotor is on the left.
I'd have to see the rims but also might make the rim design backwards? Take a picture?
Make sure the tire tread is facing the right way, and the brake rotor goes on the left from behind the bike....if the tread is wrong he put it on backwards....the manual I pasted will show you a break down of it....
Front tire doesn't matter, when can go on either way, just make sure tread is correct.
Front stem is in the middle anyways so no biggie
I know on my rear rim, I'm trying to flip it in my head and if it was on the right my rim design would flow backwards.
Notice the spikes on the outside of the rim near the valve stem? They would be backwards if I flip it
Marky-Marc
@Th3InfamousI, you seem a tad OCD, I mean CDO about your little shark fins my brotha, my front pitchforks run the same either way-going to hell or coming back....:oldhardlaugh:
You did bring up a valid point-DEPENDS on the RIMS!!!!
Haha yea on those both my bikes there is a pretty distinct way the rims need to roll. And those shark fins are tapered so the metal is thinner at the smaller portion of the fin and runs thick too end so it would look ass backwards. Although you are probably right most people wouldn't even notice..
Ill go back into my OCD hole
