Your choices are buying new pegs, factory or aftermarket with adapters or go the cheap route like I did, and make your own, I made this post a while ago about it.... http://www.bigdogbiker.com/threads/new-rubber-for-worn-out-pegs-how-to.65446/Suggestion on where to get new rubber inserts on the factory K9 pegs? Is there such a thing?
Those are actually original BDM accessories and is named Roulette. I'm rechroming mine the day it's needed cause I doubt you can find them new. I also have them for the boss (pax pegs), the grips, the ignition cover, the oil coolers, fork tops, shifter and brake, and the gas cap.I bought a pack of Arlen Ness replacements from the local dealer that fit mine. I'm sure they are available on line.
