429CV23
I finally got the Badlands Pro III lighting module installed (
), figured out how the PO screwed up the rear lights and fixed it (
), got the new rear tire installed, belt tension set, and aligned the rear wheel (they had it way off).
So ... now it's time to tackle changing the primary and transmission oils. Well OK, not NOW, probably tomorrow.
Yesterday I stopped at the local Harley dealer to pick up the oil. They were blowing out their supply of Royal Purple gear oil for $3/bottle, so I grabbed a few bottles along with 2 quarts of the HD primary/trans oil.
According to the BDM service manual, synthetic isn't recommended for the transmission, but I see that many of you are running it. Any specific issues with synthetic in the early models with 5spd? I've read the early 5spd models had Andrews gears; any issue with those and synthetic?
Also, since tomorrow it likely won't be warm enough to get rid of the ice & snow on the ground in places around here, any issue running her on the stand in 4th or 5th gear at just above idle to warm up the primary and transmission oils prior to draining them?
), got the new rear tire installed, belt tension set, and aligned the rear wheel (they had it way off).So ... now it's time to tackle changing the primary and transmission oils. Well OK, not NOW, probably tomorrow.
