ehc bd 4030 05 ???
awg
Pretty sure it will. As long as you have two connectors. Should be for a carb. Might want to ask the seller.
ground pounder
can't see the module. A efi module will work on a carb bike but not the other way, so i've been told. anything before 08 should work if its the gold module. If it doesn't pm me and i can tell you how to upgrade to the newer black module with the flipped plugs.
mml03102
I did ask the seller and he wasn't sure and didn't know what it came off of, if it doesn't go to high I will bid on it to have for a spare.
Slick117
I'm kind of leery of used electronics on fleabay......It would have to be really cheap for me to take a chance on.....
jbs1968
MEMBER
Hard, black potting material: This EHC was used for 2005 and early 2006 models. Uses a round serial cable plug for the diagnostic software and has thru-hole LEDs that protrude from the top of the potting material.
Hope this helps Joe
mml03102
I do have the 2 connectors and the same amount of leds so I would think it will work , see how high the bidding gets first .thanks all
