Glenn
Well thats interesting - the other day my low beam went out on the highway. Started to troubleshoot it and it worked fine the next morning - don't know why that happened. My 4 ways would not stop flashing when I turned them on about a month ago - started working right the next morning. This bike is 8 years old now with only 10k miles. Could very well be that the ehc is starting to go. When I had my bike tore down I went through just about everything and replaced what needed replacing. I thought maybe I could escape from the EHC demon but maybe not. My brother just finished completely rewiring his 07 pitbull - had several EHC problems. Thanks for the info - I will give it the once over before I start ripping wires out - Im just glad we are headed into winter so if I have to rewire I wont be missing those dog days of summer that I love so much! Appreciate the info!Glenn, sorry about your problems. I have an 07 K9 as well. I used chapter 15 and the chart on page 15-8 of the manual (you can download it on the forum). It outlines exactly how to troubleshoot the charging system (battery, voltage regulator, PCB, starter, stator, etc.) step by step. I had many electrical problems that were intermittent. Would get power, stop, come back, flash the 4-ways, beep the horn, then stop again. On warm days it would start, run down the street for a few miles, and stop. Had to get towed home.
After several months of troubleshooting and replacing the starter, battery, ignition, resetting the black buttons, I finally had to replace the EHC. Not sayin this is your problem but mine started like this and the only way I could figure was to eliminate everything but the EHC. This worked for me. I hope you don't have to replace the EHC because it's expensive. Good luck.![]()
Glenn
now get out there and ride the wheels off it
