chubs
v
I don't either. The guy who did the install has degrees in electrical engineering so I didn't argue.
Just a thought, Jeff: maybe that magnet holds the reed switch open, like those little battery operated door alarms. You know, the ones that when you open the door make that ungodly scream
. Could you possibly move the magnet closer to the switch and see if it helps? ((just a thought) Good luck and stay safe
ffM, post: 702052, member: 7166"]Front brake firecracker pulled out and held 4"away. No difference brake light still on[/QUOTE]Front brake firecracker pulled out and held 4"away. No difference brake light still on
I was having problems with my light as well and got a different pcb board and fixed my problem too.
Stay safe "Down under"
