Metzlers tire wear
I only got 1500 out of my last Avon and it was coming apart, I'll try an Avon if they ever fix the problem with the 300.
awg
Looks like there was to much air in the tire to wear out the center. I kept using avons without a problem. But then again I don't put on the milage you guys do.
My last Avon looked like that as well and I had two gauges that said 40lbs, so it shouldn't have been over inflated. That was after about 3-4k miles, I'm going to watch this one and may drop it to 35 if it wears like the last one.
Update: almost 1000 miles on the new avons and very happy with the wear pattern. Metzlers never really fit the bbc all that well, either rubbed on the chain or the fender. So far liking the avons
Always remember to take it a little on the easy side until you scrub the newness, or mold compound, off the tires.:whoop::old2:
Wills67
I have been running the Michelin Defenders for over 3,000 miles and they still ride and look great. Then again, my rear is only a 240. Not sure they are available in the wider tires.
I just ordered new tires for my wife's car and here is a warning note with them about mold releasing compound.
"Tires are comprised of many layers of rubber, steel and fabric. Due to these different components, your new tires require a break-in period to ensure that they deliver their normal ride quality and maximum performance. As tires are cured, a release lubricant is applied to prevent them from sticking in their mold. Some of the lubricant stays on the surface of your tires, reducing traction until it is worn away. Five hundred miles of easy acceleration, cornering and braking will allow the mold release lubricant to wear off, allowing the other tire components to begin working together."
chubs
500 miles of easy acceleration, cornering, and braking. Isn't that how we all ride anyhow?:oldconfused: Or maybe not!:panic::chopper::chopper:
