Wolf with rough idling
csaviano
good afternoon
I have a 2009 wolf 6,000 miles
The bike runs rough once it warms up to the point of cutting off. When I try to crank it, it won't. Any idea?
New spark plugs and battery
Fresh gas with stabilizer in it
Say I dump stabilizer in the tank, forgot to run it thru the carb/injector = Clogged jets/spray holes = Hard starting.
Say I haven't cleaned my air cleaner, is kind of dirty, richens the air to fuel ratio = Hard starting = hesitation = no power = dirty AC element.
Say I have electronic ign that does not change timing = Is not it.
Say I have solid lifters and the eng gets hot, opens a valve = Stalls = no start = starts better when cold.
Little-Boo
Is your dog Carbureted or fuel injected. If its carbureted you need to either replace or adjust your Accelerator Pump on the carburetor. If its fuel injected I would think its the TPS need to be replaced or calibrated. Also if carbureted there is a rubber plug on top or the Intake manifold that some times blows off and leave you with a vacuum leak which will make it run rough and give you fits till you put the plug back on. Look at that and let me know what you found. Hope that helps if not we'll keep on till we get it right.
Carlos :whoop:
