Jwooky
noDo I have to do that in order to pull the cover and check the cam numbers?
Any chance you have a part number? Or where to purchase? Couldn't find it when I checked Curtis' site.It would be wise to get a new gasket, chances are you will rip the one that's on it pulling the cam cover off... Just saying!
Check againAny chance you have a part number? Or where to purchase? Couldn't find it when I checked Curtis' site.
Franco, I've got the 107 motor and this says it fits the 111, 117, & 124. I'll keep looking.
Just head a Harley cam cover gasket for an EVO.Franco, I've got the 107 motor and this says it fits the 111, 117, & 124. I'll keep looking.Thanks
No, as soon as you pull the cover all you gotta do is look at the cam and the size will be stamped on it where it's easily visible, here's my old cam I removed,Do I have to do that in order to pull the cover and check the cam numbers?
Isn't the cam cover location pinned on the 107? If it is, like the 117, how do you expect to get the cover back on against the valve spring pressure?Do I have to do that in order to pull the cover and check the cam numbers?
Ker, I'm a noob with all things V-twin so that's why I'm asking. I've rebuilt several engines as a diesel tech back in the day but never anything this small. I don't want to do it wrong and I'm not opposed to buying a manual for the 107 if needed. I want to ID my cam so I can plan accordingly if I decide to keep the bike and get it up to BDB standards, lol. Thanks for the help.Isn't the cam cover location pinned on the 107? If it is, like the 117, how do you expect to get the cover back on against the valve spring pressure?
Thanks Eric, I found the part and placed an order on flea bay.Just head a Harley cam cover gasket for an EVO.
James Genuine 25225-93 Cam Caver Gasket For Harley-Davidson EVO Models (25225-93)
Well that's not encouraging me to touch it unless I'm prepared to go all the way. It would be a shame to pull the cover and not be able to ID the cam. Maybe my time and small budget would be better spent in getting it running right and clean, then worry about the cam.Not all cams are marked on the front where it would be easy to see what you have. Some are marked on the rear lobe, etc.
Release the push rods BEFORE you remove the cam cover. they will keep pressure on the cover, making it more difficult to remove.
As fa as cam timing on the 585, 600, 640, go on the S&S website to see the difference.
The 600 is more radical than the 585. the 640 is a heavy hitter, but a late bloomer. You need to rev the hell out of the motor to take advantage of it.
John
Now you are thinking clearly. Tune it up. The history of the 107 indicates that they were assembled by S&S and have higher compression and the 600 cam in them. Good luck!Well that's not encouraging me to touch it unless I'm prepared to go all the way. It would be a shame to pull the cover and not be able to ID the cam. Maybe my time and small budget would be better spent in getting it running right and clean, then worry about the cam.
Not sure if it has been mentioned already (can´t be bored to back and look) but have you called S&S with your engine number and asked?Franco, I've got the 107 motor and this says it fits the 111, 117, & 124. I'll keep looking.Thanks
I called S&S, they gave me the standard answer "we sold BDM the engine with no crank and don't know what is installed in it".Not sure if it has been mentioned already (can´t be bored to back and look) but have you called S&S with your engine number and asked?
Yeah.... they told me I had a 546 in there.... When I opened it I found a 569 !I called S&S, they gave me the standard answer "we sold BDM the engine with no crank and don't know what is installed in it".
