headshothills
Trying to figure out whether or not to go with the Baker or Barnett HD Clutch Diaphragm spring or order a new stock one after reading this post from last year:
http://www.bigdogbiker.com/threads/clutch-rework.61404/
08 K9
585 Cam
Unlocked ECU and Map
V&H 2-2
New Baker Hard Anodized Pressure Plate and Nut
Cleaned Injectors
Originally the clutch adjustment was all whacked out, couldn't find neutral, constantly adjusting, finally found out the Nut was backing off, ordered the new Baker hard ano'ed nut and pressure plate, mic'ed each pressure plate and they were all .120 each, mic'ed the fiber stack together and those were .865..
Called and spoke with Energy One, he says the stack is good and to get the HD Diaphragm Spring, then I came across the thread above..
Clutch slips in 3rd and up under heavy acceleration, tach races into the yellow almost immediately when you twist it fast, you can roll into it without issue, but those times you wanna ride it like you stole it, it slips..
Is anyone else running a HD Clutch Spring? I know there's others that are laying down way more HP/TQ than I am...
08 K9
585 Cam
V&H 2-2
Cleaned Injectors
