Advantage of inverted forks?
429CV23
Just curious if there is any advantage to inverted forks? I haven't seen too many BDM models with them.
I assume they will yield less unsprung weight at the wheel, but will also raise the CoG.
Will they allow more or less flex at the wheel?
Do they provide a stronger mounting point at the triple tree/frame?
Jwooky
I think the trend came from sport bikes. Having the larger diameter tubes on top added strength where is was needed. Think about the torque lever arm under heavy braking for example.
You can use the same argument for a chopper with the long fork tubes.
I personally prefer the look of the larger tubes also.
... any advantage to inverted forks?
This be a can of worms I am not familiar with, but take it for what it's worth about front ends and what little I know. Look at that front end as if the bike could 'literally' hug the ceiling like a F1 car and the ground effectshit. I doubt they would swap the shocks upside down as if right side up would make a difference. Let that sink in as 'no advantage' you look at it that way.
... they will yield less unsprung weight...
I might be wrong on this but my take on 'unsprung' is anything under the spring? So the axle, wheel bearings, bearing seals, rim, tire, balance weight, air plug; is the unsprung part I assume?
but will also raise the CoG...
No, not if you think the CoG changed with the F1 car upside down, flipped the shocks upside down, etc. Make sense so far?
I would think the fork housing sleeve would be the same clearance for oil to slip in between is the fork tube. So upside down, right side up, same flex is at the sliding gap. Still make sense?
Once you lockup the axle at the bottom, the upper crown, and lower stem pinch bolts, that axle still flexed the same as if the shocks were flipped is no change.
Which came from motocross bikes?
I have no clue, but to me, I expose less fork tube, flip the legs up the crowns; I chopped off weight. I kept the same leg length for travel, thus; Less fork tube needed = Pounds vs Stiffness?
I think I addressed that at the sleeve clearance is point Z. Flip the X or Y and Z is still the same under the same torque.
Here is where it becomes a 'dark art.' It's all about tire patch and how you angle the hinge.
I prefer to mess with the dials and springs and learn the art of the dark. Once 3-points are locked in, she is one moving unit. If I wanted to make it a plush ride, I'd cut some spring winds, toss in a cut tube as the preload height takes up those few winds, I could say I have an uncut #10 and a cutdown spring at say a 9.5 kind of spring rate. I add the 10, divide by 2 for a balanced rate set at 9.5 is the front end spring rate. Or, I could buy a #9.5 rated spring, have that full length spring in the fork; as an untampered #10 left original... that's the way they setup the high dollar front ends. Run #8's with a #10 and that says a balance of running a 9 front end setting: in the art of it.
The next deal are the compression and rebound screws. One fork leg only has a rebound adjustment, the other has the compression handled. Did not the factory look at the front end as one moving piece of balanced physics? So if I take the dark deeper, I could add that physics to a fork that has both comp and rebound in each fork and run all sorts of different settings off each fork and would it balance out?
Do the theories compute?
heybaylor
Sven, I think you have it correct, simply a move to be different.
same weight, same travel, only the "oil is in the tube"
last time I checked the bushings are in the slider,
Me , I will stay with conventional forks.
Well, heybaylor, my suspension guy said the flip was for a more rigid front end. I can't tell the difference, but a new or worn tire, yeah, like night and day.
chubs, I have to cover my ass more or less so my reality is far from yours in a sentence or less. You're not one of them there, 'runner upper's' I love to fukwit are you?
chubs
How's that bike coming along?
429CV23
Found some additional information in this article and several other sites.
http://www.motorcyclenews.com/news/2002/february/the-reason-behind-upside-down-forks/
There is a reduction in unsprung mass on the front wheel which will yield faster dampening response. Since the strongest part of the assy is attached to the frame, braking and cornering will net less fork deflection which equals a more planted feel. I was surprised to find out inverted forks are also lighter than standard forks.
Will I ever push the limits of the inverted, or even standard forks on a cruiser? Hell no. I know I did push the limits of them on my former ZX9R and ZX11. I'm sure before long I'll feel the need for speed again and will begin a search for an early, unrestricted ZX12R. Increased knowledge of the inverted forks will come in handy when I start looking for another sport bike.
