badyellowvette
After searching for a electrical problem on my K9 my ECH started smoking I decided to go with a new ESC unit.
I first pulled out the screwed up BD wiring harness and controller.
Installed the ESC unit in the same location as stock ECH. Plugged all connectors with dielectric grease and sealed with liquid tape. All wires with the new harness are lettered. A complete full colored wire diagram show what function each plug goes to, very simple.
Ran main harness through the backbone and plugged in all branch circuit connections with a dab of dielectric grease. I then sealed all connections with liquid tape. The ESC comes with a completely new braided steel headlight wire with ceramic plug. It gets rid of that three feet of coiled up wire in the 08 K9 headlight bucket.
Used the included zip ties to bundle up the wire harness.
Zip tied the backbone harness and wrapped it up in the under tank cover on the backbone.
And done, all stock functions work perfect. I did go with the electrical system monitor also. I haven't even had the dreaded starter clunk since.
