2007 mastiff headlight not working
ssinger
I have a 2007 mistiff headlight quit working replaced the bulb the high beam light on dash is flashing and there's two red lights on ech flashing any ideas thanks in advance
That flashing is the EHC telling you the headlight is burned out.
I know you said you just replaced it but pull it back out and put 12volts to it and make sure it is working.
If its working then you may have a harness or EHC issue.
If your still using the old H4 Halogen you will do yourself a huge favor by upgrading to an LED H4 replacement.
H4 LED replacement
H4 LED replacement
Go ahead and upgrade to the H4, you will not regret it. I have every dog in the county, and a couple Hogs using them, their awesome.
ssinger
Ok thanks for the help and Curtis still having trouble with my bagged gave up on it for now had s&s program me a new ecm crank it over only sparks for a second a spark goes away have to get with you on that over the winter I have spark with my original exam it fires but won't run seems to be getting to much fuel
