Max. Passenger weight on K9
whitebogger
What is the maximum passenger weight on the back of a k9 ? And also how to adjust for more weight being carried.
figure 4.4 gal of gas @ 7.5#/ gal = about 33# plus 4.5 quarts of lube, that's another 8 lbs maybe, total 41 lbs. 1130-41-200-710= about 180lbs. maximum. (legally)
Nukeranger
Nukeranger
:old2:Let's use 180lbs to be Safe (Safety First). 180-20(your personal items)-45(her personal items)-10(implants):cheers:=105lb hot chick:whoop:. Yeah, that works for me.:drool: Nice safe ride with your significant other.
Dealer told me shocks are good for 5-600 lbs with 2 people, if you adjust your shocks and the gap is getting bigger between the tire and the rear fender, you know your going the right way, adjust them evenly. There was a recall also for the bolts in the struts to have grade 8 bolts, my 07' was affected.
DRBarnhart
Insert title here...
Dealer told me shocks are good for 5-600 lbs with 2 people,..
The dealer may have said this but the factory says otherwise. Don't you think if you were in some sort of wreck and it was found out that the bike was "overloaded" as per the manufacturer specs, the long arm of the law would be reaching out for you! :eek:
Dennis
Dennis
It doesn't matter to me because my wife and I are not 5-600# :panic:and if we, on the forum, have all these differences, there's no way in hell the LEO's :dupe:would even have a clue,:oldconfused: only stated what the dealer told me.:oldread:
