Mystery Broken Piece
Found this under the bike on the lift while putting in the new clutch plate today. This was after I put it all back together and bike was sitting on the lift so not sure If it was there before. Can't be from inside the primary since its chrome.
It has 1/4x20 threads and it's 5/8 wide. Looks like a tab to the clutch cover but it's not that or primary cover I checked everywhere and can't see anything that's broke.
Handlebars - nope
Clutch actuator cover - nope
Primary cover - nope
Looked at a spare starter and nothing 1/4" . Very weird.
Marky-Marc
I know you said you looked at the Primary, but it looks like it's from the primary...or the inspection cover....I just did my clutch not too long ago as well....
5/8th is too thick for inspection cover but its fine. Yea it's really really odd!
Twisted
Never good when you end up with extra parts after a fix. No idea but hope someone will recognize it.
Marky-Marc
It looks threaded as well. Did you look at your belt cover and ball and ramp cover? I know you had to adjust your clutch after....it looks like it's from the right side of your bike....
Yep it is threaded 1/4"x20.
Checked the clutch adjustment cover too! All three tabs are whole on the cover. I think those are 5/8 bolts anyways.
Marky-Marc
@pknowles seema correct. Primary and belt covers are not threaded ON THE COVERS, just looked at my bike.....
Marky-Marc
If it AIN'T the starter, my best, educated guess (after 4 Heinekens), is it is off the INSIDE primary cover....the shape/curve, thread size and everything seems to match up....hate to be the devil, but you may have to drain and pull the outer cover again.....but there doesn't seem to be anything else threaded except the starter and the INSIDE primary cover....
Marky-Marc
IF it is indeed from the inside primary, when you go for a ride and your primary leaks....you will know.....cheers.....
Coolbreezin
How clean or dirty was it when you found it? That would give you an idea of where it may be on the bike. If its filthy, then Id say it was along the frame under the engine. If clean, then you probably wipe it regularly, maybe open area around the engine.
