Anyone have this happen where one of the rocker bolts leaks? It's not the gasket it leaks through the bolt hole. I retorqued to 120inch lbs per the manual and still get a leak occasionally it just makes a mess on the bike otherwise I wouldn't worry.
It's the middle bolt on the front side, I'll try and getting a better picture but it leaks just a few drips then stops. This picture was taken after I had got home and probably 50 miles of leak free riding so it just splattered everywhere as you can see by the oil on the coil cover.
Other than pulling it out cleaning the threads and re applying red loctite, which I don't see how that will work. I'm not sure what to do.
Head pressure building up every once in a while and sending it out through the bolt hole? Weird....
.. I'm just going to go ahead and replace all 6 with 1" bolts now.
Shit, between you and Ker you guys could have your own parts warehouse!
, lucky for me (and a lot of others) you guys got your shit together!
Thanks for all the info and help!
