Carb issue
B-DUB74
2005 chopper. Bought her last year with 1000 miles. Rebuilding all worn components. Rejet her yesterday and when I fired her up she went straight to max RPM. Scared the shat out of me. The Jets that were in her main 068, intermediate 072. Replaced them with 078 main and 032 intermediate. Cleaned everything as well. No idle, straight to screaming. Thoughts?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
B-DUB74
I'm at work but I will check when I get home. I won't rest until it's right.
B-DUB74
Bingo. Throttle speed screw cranked all the way down. I'm putting her together now. I'll let you know in a minute.
Now I gotta figure this vibration that just showed up.
This could be a lot of things! Handlebar bushings or motor mounts loose, alignment issue or cracked frame. Can you explain more! Speed?? Front end etc...
B-DUB74
Development right at 1500rpm. Done a little reading. Gonna check belt tension and clutch. Just rejet the carb and she has considerably more power. Something probably got loose or stretched
Don't think that is the issue! Did you adjust the alignment?
B-DUB74
No. It feels more like a motor vibration more than a chassis shake. She handles real good even at high speed.
