Dubbs_
I know this has been beat to death but I haven't been able to find the answer I'm looking for...
I've had the bike a few months and only rode it a dozen times or so... The last time I rode it I gave it a good flogging and developed a rattle sound... Sounded kinda like a loose heat shield... But the only way to replicate it was to drive the bike... Kinda sounded like the drive chain was rubbing on something... So I took the cover off to inspect everything... Everything looked ok and the chain was adjusted to spec... Filled with new oil and test rode the bike to find the noise still there... While looking everything over I found that the top motor mount bolt was missing... Installed a new bolt but the noise was still there... Continued to look everything over and found that the belt was way too loose... This was strange to me because I'd checked it before and it was a tad on the loose side but still plenty tight... Well I just figured I must of rode it harder than the previous owner and put a good stretch on it... Tightened the belt but the noise was still there... Under further inspection I found my noise... The belt was rubbing on one of the bolts that hold the front belt guard... Where my thumb is...
Removed the cover to make sure the bolt was tight and it was... But with the cover off I noticed that the belt was running in a new location...
It's about a 1/4" away from the motor from where it was...
And the belt is actually off the gear/pulley an 1/8" or so...
So I thought I could correct it by fudging the back tire... If I get the back tire way out of whack I can get it better but not where it was running... So I measured and got the wheel alignment correct to start over and the belt went back to where it is pictured above...
FYI This is how I aligned the rear wheel...
Something has changed and I can't find it... All of the transmission bolts are ok and nothing looks like it has/can move but it's almost like the transmission has shifted... I don't think I stretched the belt... I think I have a larger problem... How crazy am I??? What am I missing???
Thanks guys!!!
Thanks guys!!!
