How do you know if your wires are surpressed or not Franco? And how would that effect your tach?....
Non suppressed ignition wires emit radio waves. If you've ever heard the alternator whine in a car stereo system, it's kind of the same thing, but worse. If you have ever been at a red light and had a hot rod car with non suppressed ignition wires pull up next to you, you will hear it affect your radio.
Now, that being said, just about every electronic thing you can buy for a motorcycle used to have a requirement to mount the electronic brain 1 meter (3 feet) minimum from the coil and ignition wires. This is because of the radio wave interference that is caused by the coil and ignition wires.
Now, I wish someone could tell me where you can mount anything on a Big Dog that is more than 3 feet from the coil. Maybe the leading edge of the front fender.
But now most things no longer have this warning, I saw one for 30cm (12 inches) but that was about it (but it did require radio suppressed wires). I guess most things are shielded now. Thunderheart used to have this warning for their ignition module, now they have a bracket to mount it directly to the coil.
